what is the use of redundant vias ?
ja123
Newbie level 3
hi, can anyone tell me , why we go for the redundant vias .... and what are the effects of using the redundant vias
If you are talking about multiple vias for one connection...
effects/advantages
1effective connection resistance reduces because of parallel connection.
2probability of yield reduction due to spot defect or improper manufacturing greatly gets reduced.
3.in deep sub micron technologies increased cap may be noticed.
Reactions: ja123
    ja123
does it effects timing ??
Of course it affects timing. RC time constant is about two times bigger for one via, than for two vias.
Reactions: ja123
    ja123
This is only valid for very short connections. For long connections, the metal resistance of the wire would be dominant.
Reactions: ja123
    ja123
You are right, but it's just an example. And it depends on technology. Single via can have quite big resistance, for example in one of newest technologies via between metals can have from 20ohms to 100ohms resistance (source - technology documentation). So even for long connection it can have some significant impact if you use only one via.
Reactions: ja123
    ja123
I think the main reason is to maximize the yield....You dont want your chip to not work coz of a single via getting burnt off..
Reactions: ja123
    ja123
Right, but it's not because burning off (for higher currents you need an array of vias anyway), but the minimal overlap used in submicron processes. Already a small misalignment together with some angle tilt during metal deposition may cause metal coverage failing inside the still accessible via wall. See e.g.
Reactions: ja123
    ja123
I once had a layout person use a single via connecting M1 to M2 in the output metal of a power op-amp. imagine the fun the customer would have had when passing 200mA
through a single via..........
Reactions: ja123
    ja123
Thats what it all comes down to...yield==no.of successful chips..Put more vias get more out of your chip
    V
also you could see multiple vias for thermal disapation. usually these vias however would not connect to any other net.
