What is the use of grid size?
mujju433
Full Member level 3
Full Member level 3
What is the use of grid size??
What is the diference between routing grid adn manufacturing grid ??
I will be grateful to u if anybody can explain me about this plz
Bye take care
Re: doubts on grid
The grid helps you to obtain a better/regular placement and routing. For example, if you wouldn't have the grid, you could route at any distance from the next route, allowing you to place the track on the top of the other track. During the routing you can use any grid you want, but take care because the pick & place machines that equip the boards have a certain granularity of the placement, and the PCB manufacturers also have a minimum distance between the tracks. You should check this with your manufacturer.
Re: doubts on grid
How do I decide the grid size for my design?
Added after 1 minutes:
Hi can u please tell me how can we decide the size of grid for a design?
