Jul 3, 2006 #1 K km Junior Member level 3 Joined May 26, 2004 Messages 31 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 322 What is the simplest method to convert a triangle wave to sine wave ( Range:- 0 to 100kHz ):?:
Jul 3, 2006 #2 R rkodaira Full Member level 6 Joined Jun 8, 2004 Messages 331 Helped 68 Reputation 136 Reaction score 12 Trophy points 1,298 Location Sao Paulo - Brasil Activity points 4,092 Re: Triangle to Sine If the frequency is fixed, try bandpass filters. If not, the function generators ICs use transistors in non-linear arrays to format the waveform to sinewave like (there always a tip and the wave is not soft).
Jul 3, 2006 #3 Davood Amerion Advanced Member level 2 Joined Mar 1, 2005 Messages 579 Helped 116 Reputation 232 Reaction score 24 Trophy points 1,298 Location Persia Activity points 6,345 Triangle to Sine check internal circuit of ICL8038. you can use this IC, too.
Jul 4, 2006 #4 V venkateshr Member level 3 Joined Feb 1, 2005 Messages 63 Helped 3 Reputation 6 Reaction score 2 Trophy points 1,288 Activity points 503 Re: Triangle to Sine U can approximate a triang wave to a sine wave by some wave shaping network comprising only resistors and diodes. u can smoothen the peak and that moulds ur triang to a decent sine wave. this is the simplest thing to use .
Jul 5, 2006 #5 P pixel Advanced Member level 2 Joined Sep 16, 2004 Messages 508 Helped 69 Reputation 138 Reaction score 16 Trophy points 1,298 Activity points 3,993 Re: Triangle to Sine Look here:
Jul 5, 2006 #6 Borber Advanced Member level 5 Joined Dec 31, 1999 Messages 1,600 Helped 235 Reputation 472 Reaction score 111 Trophy points 1,343 Location on third flor Activity points 11,863 Re: Triangle to Sine some articles
Jul 5, 2006 #7 K km Junior Member level 3 Joined May 26, 2004 Messages 31 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 322 Re: Triangle to Sine Can i get a Sine Wave (same frequency with the input) from the Function Generator ICs (XR2206) by inputting either triangle or square wave into it?
