what is the purpose of a diode with the rechargeble battery?
sunnystar
Junior Member level 3
what is the purpose of a diode with the recharageble battery? is that true, to prevent the incoming voltage from the adopter being reversed otherwise battery gets short??
Diodes in addition to 1-way switches for current are also thermometers with a small negative temperature coefficient (NTC) on forward voltage and can be used to sense battery completion of charge by a temperature rise which can then drop the control voltage to a safe float voltage or cutout entirely. This is most useful in multi-cell batteries. If one cell is dead or a low voltage short, then voltage or current feedback is not a safe sensor to use for charging the battery.
How, where the diode is used depends on design details you omitted in your question.
circuit of rechargeable battery is attached
The diode prevents the battery from discharging into the charger when the charger is turned off or when there is no power to the charger.
Why is there a switch that shorts the battery and maybe causes a fire?
I think Audioguru is playing with you!
What he is pointing out is the switch in your schematic appears to be across the battery. If you close the switch a high current will flow and something will overheat badly, possibly starting a fire. In a schematic it is often impossible to avoid crossing lines so it is very important to show whether they are actually connected to each other or not. Convention is to use a round blob (a big dot) when the crossing wires are joined and either no blob or a 'bridge' (like the symbol on a map) when they are not joined.
Answering your original question, the diode is to allow charge into the battery but prevent it going back to the charger port if the supply is turned off. The diode will only conduct when it's anode has more voltage on it than it's cathode. In your diagram, it means if the charger voltage is higher than the battery voltage, current will flow into the battery and charge it. If the charger voltage is lower or not there at all, the diode will prevent the battery conducting back to the charger port.
Brian.
thanku so much brian sir for your great help and time.... :razz:
somebody can help me in blocking irritating adds of 'Ads by OffersWizard' ?? :cry:
