T
treez
We are designing a 60W offline flyback.
We notice that the L6566B pwm controller, in fixed frequency mode, can vary the switching frequency from 82KHz to 88Khz, if we wish it to. (ie the switching frequency is constantly going up and down between these two frequencies, at about 1Khz)
It is said that this offers ease in passing EMC.
But how can this be so?
The main problem for EMC in SMPS is the harmonics of the switching frequency, not the switching frequency itself. It is the high di/dt and high dv/dt currents and voltages that create the problem, and these are not eased by varying the switching frequency as described. So what is the point of varying the switching frequency as described?
L6566B datasheet:
https://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00167474.pdf
L6566B datasheet:
