What is the output voltage of a 3 phase VFD?
Re: What is output voltage of 3 phase vfd
Here is some results
This is input voltage
This is output voltage phase to phase
:bang::bang:
:roll::roll:
As long you don't show oscilloscope waveforms of DC-bus to phase and phase to phase, I can't comment the measurement.
I presume it's 3x120° system, not 90° which has of course lower output voltage.
Reactions: abc_de
    abc_de
Hello
Here is some output by Rc Filter
Yes these measurements are 120degree phase shift
This is output of spwm by which i am getting lower voltage from expectation
Around 175vac phase to phase
This output of saddle pwm from both lower and higher channel of pwm
Output voltage with spwm and saddle pwm is almost same still spwm gives more output voltage
The second and third waveform look very different from any expectable inverter output. No idea how you managed top get it.
Reactions: abc_de
    abc_de
i also thinking waveform is not like expected
in 1st pic i use sine table method.
