DEV123
Member level 2
In the above circuit the input (DC with a ripple superimposed) is given between node A and GND. My doubt is whether the output is a filtered one (ie without ripples) or non-filtered one (ie input itself) ? Most of my colleagues say that output is a filtered one because of capacitor. But according to KVL the voltage across the node A and GND must be same from both directions, is not it? If a voltage is applied across a node and gnd it has to be the same at output also in this case , so what is the output?
