What is the meaning of "offset between the threshold voltages"
Rahul Sharma
Member level 3
Member level 3
Guwahati, INDIA
If we talk about basic circuit of current mirror designed using MOS transistors. then how will be calculate the offset between the 2 transistors of basic cell ????
If you have mismatch (Avt) parameters from the foundry/fab you can calculate worst case offset values for adjacent transistors, depending on their size. Or you can run a Monte Carlo analysis if you have the corresponding mismatch set.
