what is the main essence of generate block and how is it useful??
anusha vasanta
Member level 1
Member level 1
genvar a;
			generate
			for(a=0;a<=7;a=a+1) //converting input data_in bits into bytes format
			begin : MEM
			 assign data[a]= data_in [((a*8)+7):(a*8)];
			end
			endgenerate
hi all, here i had one generate which is converting my bits into bytes of 8. is taking the conversion in gen block will reduce my no.of clock cycles?
will i get the o/p of 8 bytes in one clk during my elaboration phase?? help me thanku
Generate statement is used to replicate hardware without the need to write explicit pieces of code.
In the example you have shown, you don't need separate code for data[0], data[1],data[2]..and so on. The given piece of code will do the job.
thanku then in how many clock cycles we can get the o/p for a generate block of above kind.
U can get the output in a single clock. This is because all the different pieces of hardware generated will work at the same time.
