what is the difference between NMOS and PMOS inverters
praveen_akshay
difference between nmos and pmos
what is the difference between NMOS and PMOS inverters in terms of the transfer function
pmos inverter
You can read Microelectronics by Jacob Millman
differences between pmos and nmos
a nmos inverter consists of a nmos transistor with a resistor attached to Vdd (by drain).
a pmos inverter has an pmos transistor and a resistor to ground.
the common used inverter is the cmos inverter with both the nmos and the pmos transistor.
inverter nmos pmos
that's Common Source Amp!
