Jul 1, 2016 #1 U u24c02 Advanced Member level 1 Joined May 8, 2012 Messages 404 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 4,101 Hi, I'd like to connect to 3 fpga board but those fpga boards are moved away about 3 meter. In this case, I'd like to know which the connection methodologies are better approch. 1 zynq board 2 atrix boards Star connection between them. Last edited: Jul 1, 2016
Jul 1, 2016 #2 ads-ee Super Moderator Staff member Joined Sep 10, 2013 Messages 7,944 Helped 1,822 Reputation 3,654 Reaction score 1,808 Trophy points 1,393 Location USA Activity points 60,207 Another poorly posed question using nearly incomprehensible English, that lacks any requirements, typical u24c02 question :roll: rs422 would work great based on the information provided. ------------------- Edit I see you've improved your question.
Jul 1, 2016 #3 U u24c02 Advanced Member level 1 Joined May 8, 2012 Messages 404 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 4,101 Thanks but they have each resister map and need to 40MB/s over. Is there any good communication protocol between each other?
Jul 4, 2016 #4 S std_match Advanced Member level 4 Joined Jul 9, 2010 Messages 1,304 Helped 463 Reputation 926 Reaction score 448 Trophy points 1,363 Location Sweden Activity points 10,180 Is it 40 Mbit/s or 40 MByte/s ? With 40 Mbit/s you can use LVDS and the old UART protocol. You may have to design the UART yourself, but it is easy. With 40 Mbyte/s = 320 Mbit/s you will have some trouble unless your FPGAs have high-speed serial transceivers or Gigabit ethernet.
