What is the audio mono mix/and sterero?
boeysue
Full Member level 3
What is audio mono mix and stereo ?
and what it for? thanks for answering.
hi,
audio mono mix stands for single audio component for both the ears. i.e. both left as well as right speakers would give you the same sound which is not so in case of real life where your left and right ears are located at different position in space and hence sound that comes to you is different as heard by left ear then what is heard by right ear.
Stereo resolves the sound into left and right component and helps you to hear as if it is real sound.
pimr
so mono mix ,the data output is single output?
why I see some document one chanel is ch1 +ch2 the other is ch1-ch2??
What is the mono mix?
