Mar 21, 2010 #1 U ubaid_666 Newbie level 2 Joined Mar 21, 2010 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location karachi Activity points 1,294 hi can any one tell me what is s11 parameter of patch antenna and what is s11? how can i find s11? plz answer me as soon as possible
Mar 21, 2010 #2 V volker_muehlhaus Guest S11 is the input reflection factor: how much of the input signal is actually reflected back to the transmitter. You can convert S11 to the VSWR, which is another parameter to describe antenna matching: **broken link removed**
Mar 22, 2010 #3 mauloftin Full Member level 6 Joined Oct 29, 2008 Messages 355 Helped 62 Reputation 122 Reaction score 36 Trophy points 1,308 Location CZ Activity points 3,285 volker_muehlhaus said: S11 is the input reflection factor: how much of the input signal is actually reflected back to the transmitter. You can convert S11 to the VSWR, which is another parameter to describe antenna matching: **broken link removed** Click to expand... .... and about VSWR you can read here: **broken link removed** or https://en.wikipedia.org/wiki/Standing_wave_ratio it is about Return loss: https://en.wikipedia.org/wiki/Return_loss in this case you: s11 = RL, it is the same. If you know exactly, what is the s11, try search "Scattering Matrix" or "S-PARAMETERS", for example: **broken link removed** I hope, that I helped you
