What is Noise Format In *.S2P file?
liuzhili
Member level 3
Member level 3
I found In S2P file ,the first part is declare,the second is S-para,but in the third part,I do not understand it means,I know it is noise para,but what is it mean? the first row of it is freq,but what is and the second,third,..row?
thank u
flatulent
Advanced Member level 6
Middle Earth
source
Page 3 of this document shows the parameters **broken link removed**
They involve the lowest noise figure and the source impedance that produces it.
Here is a screen shot of that part of the document.
Reactions: dorsa
    dorsa
Element_115
Advanced Member level 2
Just one thing to add to S2P(SnP) files, is that the formats can be different.
Default Option Line
The default option line for component data files is:
# GHZ S MA R 50
Option Line Examples
Frequency in GHz, S-parameters in real-imaginary format, normalized 100 ohms:
# GHz S RI R 100
Frequency in KHz, Y-parameters in real-imaginary format, normalized 100 ohms:
# KHz Y RI R 100
Frequency in Hz, Z-parameters in magnitude-degree format, normalized to 1 ohm:
# Hz Z MA R 1
Frequency in KHz, H-parameters in real-imaginary format normalized to 1 ohm:
# KHz H RI R 1
Frequency in Hz, G-parameters in magnitude-degree, format normalized to 1 ohm:
# Hz G MA R 1
RI = Real and Imaginary
MA = Mag and Angle
as for noise.
Adding Noise Parameters to an SnP File
Noise parameters can be included in SnP 2-port data files. Noise data can follow G-, H-, S-, Y-, or Z-parameters described for each frequency. The x values are data.
Each line of a noise parameter has the following five entries:
x1 x2 x3 x4 x5
where
x1 = Frequency in units. The first point of noise data must have a frequency less than the frequency of the last S-parameter frequency
x2 = Minimum noise figure in dB
x3 = Source reflection coefficient to realize minimum noise figure (MA)
x4 =Phase in degrees of the reflection coefficient (MA)
x5 =Normalized effective noise resistance. The system simulator requires this parameter to meet physical requirements. If the user-supplied x5 value is less than allowed for this requirement, then the system simulator will force this x5 value to the lowest physical limit.
Cheers
Reactions: dorsa
    dorsa
flatulent
Middle Earth
x1
the X1 description in the previous post is very important. The CAD program can only tell if the noise lines are noise if the frequency goes back down compared to the previous two port parameter data lines.
