What is compensated device?
leonken
Full Member level 3
When I reading a paper, I found the word:compensated device.
Thank you.
give the reference of the paper or write down the whole phrase.
Broadly speaking, I would think it was an extra addition to the circuit which would reduce any variation in the output due to changes in internal/external parameters
e.g. a temperature compensated circuit.
by adding some device to reduce the non-ideal characterisc which is don't need. such as pole-zero point compensated to add the stability,
It is sometime refered to devices to eliminated non-linear characteristics.
Thank you.
I think it's better to show us the paper or the field you are studying now.
So that, we can identify the question.
