Depending on the number of DIO lines you need, most of their boards have 20 DIO lines or more, their linux based with drivers and API freely available, great technical support and the are pc/104 based with DIO modules with up to 64 lines. The TS-7200 cost me around $100, works great.
Of course if you want to implement it from the ground up, then FvM suggestion of a uP with some glue is probably the quickest route. Check out this open source TCP/IP Suite I've used in the past:
