cipherstream
Newbie
- Joined
- Oct 14, 2014
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,335
I want to electronically "switch" a signal line between 2 or more possible paths. I don't need to switch paths very often and when I do it only needs to switch within 100ms or less.
The signal line is 3.3V and the datarate on it can reach 80-100MHz. The direction of the signal can also change due to events/timing that would be very hard to know about in advance.
So basically I need the equivalent of a manual, physical switch, but one that I can switch electronically. I would like to be able to switch using another 3.3V signal line. Once you have thrown a manual switch the signal can pass in either direction, there is no propagation delay and the datarate over it doesn't matter, so this is what I am after.
I have been reading and searching on the internet for a few days, but I am too n00b to know what it is I need. It seems a relay would work, but would be overkill since I would be switching it with the same voltage that I am using it to then pass through. I also read about multiplexers/demultiplexers, but it seemed they only sent a signal one way. I also read about IDT bus switches but I wasn't sure if they sent signals both ways, it looked like they didn't either.
So someone please tell me what it is that will do what I want so I can read up some more about it
