SAW filter
(Surface Acoustic Wave filter) A semiconductor device that is used to filter out desired frequencies. Widely used in mobile phones to filter both RF and IF frequencies, a SAW filter uses the piezoelectric effect to turn the input signal into vibrations that are turned back into electrical signals in the desired frequency range.
Two sets of metal electrodes like teeth on a comb are adhered to a quartz crystal and spaced apart (in microns) based on the required frequencies. As few as five and as many as 5,000 electrodes are used. An intriguing analogy from Bruce Thomas at Sawtek is that the first set of electrodes is like throwing a large log into a pond, which makes huge waves that cause little sticks to bounce out at the other side (second set).
Added after 1 minutes:
SAW (surface acoustic wave) filters are electromechanical devices commonly used in radio frequency applications. Electrical signals are converted to a mechanical wave in a piezoelectric crystal; this wave is delayed as it propagates across the crystal, before being converted back to an electrical signal by further electrodes. The delayed outputs are recombined to produce a direct analog implementation of a finite impulse response filter. This hybrid filtering technique is also found in an analog sampled filter. SAW filters are limited to frequencies up to 3GHz.
