liletian
Full Member level 6
hi Guys
Can anyone explain what RF choker is? Is RF choker same as balun? If I want to test a dipole antenna without ground plane, is RF choker enough or I need a special balun?
Also, can you also explain what balun is physically. I knew balun is used to transfer between balance and unbalance signal. In a frequency like 2GHz, how you can make a balun? This is because of the curiousity.
Will balun transfer impedance of 10+50j into same 10+50j.
Thank you
Thank you
