cupoftea
Advanced Member level 5
Wiki says a ground loop is...
...Surely this is not central to what a ground loop is all about?
A ground loop is literally that....a loop of conductor that is all of the ground net.
The problem with it is that it unfortunately acts like a loop antenna and receives noise and transmits it out..
Surely a ground loop is what you get when you have an offline SMPS with an earth input..... The earth is also taken across the isolation barrier where it connects to secondary ground...then someone connects something else to the secondary side, which also is connected to mains earth...then you obviously get an enornous earth ground loop going back through the wall socket , and through the building earth cableing. This is surely the largest and most awful (for EMC) exampel of a ground loop.
The other example is when we had 34 Vicor SMPS modules in parallel.......it obviously wasnt possible to have a single huge ground plane under all 34 of them....so we ended up with enormous ground loops...and had to put common mode chokes in each module's output, so as to break up the ground loops.
in an electrical system, a ground loop or earth loop occurs when two points of a circuit are intended to have the same ground reference potential but instead have a different potential between them.
