Mar 5, 2007 #1 V verilog_always Member level 2 Joined Dec 27, 2006 Messages 43 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,288 Activity points 1,552 what is the command @ARGV means. And how it is used in perl.
Mar 5, 2007 #2 H hunter694 Member level 2 Joined Aug 11, 2004 Messages 48 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,288 Location Sweden Activity points 299 Re: perl-ARGV ARGV is not a command. It is a default array variable holding a list of the command line arguments. When you look in the @ARGV array, you find all the parameters or arguments that were passed to the perl script at invocation. more info **broken link removed**
Mar 6, 2007 #3 V verilog_always Member level 2 Joined Dec 27, 2006 Messages 43 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,288 Activity points 1,552 Re: perl-ARGV Hi hunter694, Can u please provide any example, to understand it.
Mar 6, 2007 #4 H hunter694 Member level 2 Joined Aug 11, 2004 Messages 48 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,288 Location Sweden Activity points 299 perl-ARGV **broken link removed** is a page that explains how to rename files using a perl script. It uses @ARGV array to read the file names passed to the perl script by the user through command-line.
Mar 6, 2007 #5 ahmad_abdulghany Advanced Member level 4 Joined Apr 12, 2005 Messages 1,206 Helped 102 Reputation 206 Reaction score 22 Trophy points 1,318 Location San Jose, California, USA Activity points 11,769 Re: perl-ARGV It represents the default argument (array argument).. It's a special variable that can be used in Perl.. You may use it when u want your perl script to take values from the command line arguments.. Hope that helps you.... Ahmad,
