This error can easily be overcomed by going to SETUP-->DESIGNRULES-->DECALS select all the decals and set all the rules then again make it DEFAULT rule.Repeat the same for all COMPONENTS also.
Then in SETUP-->DESIGNRULES-->DIFFERENTIALPAIRS see that no pairs are present in the PAIRS column
Hello,
I face the same problems with latium rules.I tried the options mentioned by you i.e by deleting the component & decal rules...
but i still see there are some different rules set for fiducial pads, 7 some conentors... which never goes after i delete it also.. It says as (fp) rules... i have no idea what it means...
please help me on this regard.
