atul_microwaves_antenna
Member level 5
Hello All,
I am bit digging up topic of Antenna Gain/ Antenna(System) Temp. It is popularly known as G/T ratio of an antenna and it is one of the very important parameters for antennas used in Satellite communication.
I wonder what dose it really signify? Better the G/T ,better the antenn, it simply means that lower the Antenna temp(noise) .Also better the G/T higher the effective aperture of an antenna.It is all about a ratio analysis.But I wonder I one uses this G/T ratio to design an antenna? a receiving antenna...?
Thank you..
Thank you..
