=agauss(
Syntax: AGAUSS(nominal_val, abs_variation, sigma <,+ multiplier>)
Gaussian distribution function using absolute variation
nominal_val - Nominal value for Monte Carlo analysis and default value for all other analyses.
abs_variation - AGAUSS varies the nominal_val by +/- abs_variation.
sigma - The abs_variation is specified at the sigma level. For example, if sigma=3, then the standard deviation is abs_variation divided by 3.
multiplier - If not specified, the default is 1. The calculation is repeated this many times and the largest deviation is saved. The resulting parameter value might be greater or less than nominal_val. The resulting distribution is bimodal.
