Re: Assembly Drawings
In my previous mail, i have posted a link which clears your doubt,check that link again,
https://www.unisoft-cim.com/pcbview.htm
check the link,go through it completely,you see call out(captions),this is how it looks after ur done with ur assembly drawing, which will guide you in step by step assembly process.
The task will be similar to silk screen( legend print),but then you need to place the reference designator inside the component outline,please refer the link above,in addition to that,they also give some instructions(captions),like which component to mount first,consequently letting them to entire assembly process,for eg,
1) Place all the smd resistors.
2) Place all the smd capacitors.
3) place all the smd diode and so on,it just easing the assembly process,but then you need to forsee,you can take guidance from the assembler,he might guide you in entire procees,all the best.
Hope you understood and helped.
Regards
Ramesh
