What diode to use for circuit operating radio (10-20MHz)?
Catalyst
Full Member level 3
Full Member level 3
Diode Question....
Hey all,
What type of diode is generally recommended for a circuit operating at radio frequency between 10 and 20 MHz? I am trying to provide good half-wave rectification.
I've used a 1N4148 type diode but the rectification becomes very noisey at frequencies over a few hundred KHz.
Would a small signal Germanium diode do the trick?
Cheers
Cat
Diode Question....
Try to use the 1N914, I used it in an FM tx at 87.8MHz
Hope this helps.
Re: Diode Question....
I would try the Germanium one but also are you using more than just the diode? Maybe adding a small capacitor would do the trick.
