What caused errors when compiling U-Boot?
ttxs
Junior Member level 1
I followed the instructions in http://xilinx.wikidot.com/mb-uboot to compile U-boot
linux-host> export BUILD_DIR=$PWD/build
linux-host> make microblaze-generic_config
linux-host> make
And I got the following information on the terminal:
  CHK     include/config.h
  UPD     include/config.h
  GEN     include/autoconf.mk
  GEN     include/autoconf.mk.dep
  GEN     spl/include/autoconf.mk
  CHK     include/config/uboot.release
  UPD     include/config/uboot.release
  CHK     include/generated/version_autogenerated.h
  UPD     include/generated/version_autogenerated.h
  CHK     include/generated/timestamp_autogenerated.h
  UPD     include/generated/timestamp_autogenerated.h
  CC      lib/asm-offsets.s
  CHK     include/generated/generic-asm-offsets.h
  UPD     include/generated/generic-asm-offsets.h
  HOSTCC  tools/envcrc.o
  WRAP    tools/lib/crc32.c
  HOSTCC  tools/lib/crc32.o
  WRAP    tools/common/env_embedded.c
  HOSTCC  tools/common/env_embedded.o
  WRAP    tools/lib/sha1.c
  HOSTCC  tools/lib/sha1.o
  HOSTLD  tools/envcrc
  HOSTCC  tools/gen_eth_addr
  HOSTCC  tools/img2srec
  HOSTCC  tools/mkenvimage.o
  HOSTCC  tools/os_support.o
  HOSTLD  tools/mkenvimage
  HOSTCC  tools/aisimage.o
  HOSTCC  tools/atmelimage.o
  WRAP    tools/common/bootm.c
  HOSTCC  tools/common/bootm.o
  HOSTCC  tools/default_image.o
  WRAP    tools/lib/fdtdec_common.c
  HOSTCC  tools/lib/fdtdec_common.o
  WRAP    tools/lib/fdtdec.c
  HOSTCC  tools/lib/fdtdec.o
  HOSTCC  tools/fit_common.o
  HOSTCC  tools/fit_image.o
  HOSTCC  tools/gpimage.o
  HOSTCC  tools/gpimage-common.o
  WRAP    tools/common/image-fit.c
  HOSTCC  tools/common/image-fit.o
  HOSTCC  tools/image-host.o
  WRAP    tools/common/image.c
  HOSTCC  tools/common/image.o
  HOSTCC  tools/imagetool.o
  HOSTCC  tools/imximage.o
  HOSTCC  tools/kwbimage.o
  WRAP    tools/lib/md5.c
  HOSTCC  tools/lib/md5.o
  HOSTCC  tools/lpc32xximage.o
  HOSTCC  tools/mxsimage.o
  HOSTCC  tools/omapimage.o
  HOSTCC  tools/pblimage.o
  HOSTCC  tools/pbl_crc32.o
  HOSTCC  tools/socfpgaimage.o
  WRAP    tools/lib/sha256.c
  HOSTCC  tools/lib/sha256.o
  WRAP    tools/common/hash.c
  HOSTCC  tools/common/hash.o
  HOSTCC  tools/ublimage.o
  WRAP    tools/lib/libfdt/fdt.c
  HOSTCC  tools/lib/libfdt/fdt.o
  WRAP    tools/lib/libfdt/fdt_ro.c
  HOSTCC  tools/lib/libfdt/fdt_ro.o
  WRAP    tools/lib/libfdt/fdt_rw.c
  HOSTCC  tools/lib/libfdt/fdt_rw.o
  WRAP    tools/lib/libfdt/fdt_strerror.c
  HOSTCC  tools/lib/libfdt/fdt_strerror.o
  WRAP    tools/lib/libfdt/fdt_wip.c
  HOSTCC  tools/lib/libfdt/fdt_wip.o
  HOSTCC  tools/dumpimage.o
  HOSTLD  tools/dumpimage
  HOSTCC  tools/mkimage.o
  HOSTLD  tools/mkimage
  HOSTCC  tools/ncb
  HOSTCC  tools/proftool
  AS      arch/microblaze/cpu/irq.o
  CC      arch/microblaze/cpu/cpu.o
  CC      arch/microblaze/cpu/interrupts.o
  CC      arch/microblaze/cpu/cache.o
  CC      arch/microblaze/cpu/exception.o
  CC      arch/microblaze/cpu/timer.o
  LD      arch/microblaze/cpu/built-in.o
  AS      arch/microblaze/cpu/start.o
  CC      arch/microblaze/lib/bootm.o
  CC      arch/microblaze/lib/muldi3.o
  LD      arch/microblaze/lib/built-in.o
  CC      board/xilinx/microblaze-generic/microblaze-generic.o
  LD      board/xilinx/microblaze-generic/built-in.o
  CC      common/main.o
  CC      common/exports.o
  CC      common/hash.o
  CC      common/cli_hush.o
  CC      common/autoboot.o
  CC      common/board_f.o
  CC      common/board_r.o
  CC      common/cmd_boot.o
  CC      common/cmd_bootm.o
  CC      common/bootm.o
  CC      common/bootm_os.o
  CC      common/cmd_help.o
  CC      common/cmd_version.o
  CC      common/env_attr.o
  CC      common/env_callback.o
  CC      common/env_flags.o
  CC      common/env_flash.o
  CC      common/cmd_source.o
  CC      common/cmd_bdinfo.o
  CC      common/cmd_console.o
  CC      common/cmd_echo.o
  CC      common/cmd_exit.o
  CC      common/cmd_ext2.o
  CC      common/cmd_fat.o
  CC      common/cmd_fdt.o
  CC      common/fdt_support.o
  CC      common/cmd_flash.o
  CC      common/cmd_gpio.o
  CC      common/cmd_irq.o
  CC      common/cmd_itest.o
  CC      common/cmd_jffs2.o
  CC      common/cmd_load.o
  CC      common/cmd_mem.o
  CC      common/cmd_mfsl.o
  CC      common/miiphyutil.o
  CC      common/cmd_mii.o
  CC      common/cmd_mdio.o
  CC      common/cmd_misc.o
  CC      common/cmd_mtdparts.o
  CC      common/cmd_net.o
  CC      common/cmd_pcmcia.o
  CC      common/cmd_test.o
  CC      common/cmd_ubi.o
  CC      common/cmd_ximg.o
  CC      common/cmd_spl.o
  CC      common/flash.o
  CC      common/splash.o
  CC      common/cmd_nvedit.o
  CC      common/env_common.o
  CC      common/console.o
  CC      common/dlmalloc.o
  CC      common/malloc_simple.o
  CC      common/image.o
  CC      common/image-fdt.o
  CC      common/image-fit.o
  CC      common/memsize.o
  CC      common/stdio.o
  CC      common/cli_simple.o
  CC      common/cli.o
  CC      common/cli_readline.o
  CC      common/command.o
  CC      common/s_record.o
  CC      common/xyzModem.o
  CC      common/cmd_disk.o
  LD      common/built-in.o
  CC      common/env_embedded.o
  CC      disk/part.o
  CC      disk/part_dos.o
  LD      disk/built-in.o
  CC      drivers/block/systemace.o
  LD      drivers/block/built-in.o
  CC      drivers/crypto/fsl/sec.o
  LD      drivers/crypto/fsl/built-in.o
  LD      drivers/crypto/rsa_mod_exp/built-in.o
  LD      drivers/crypto/built-in.o
  LD      drivers/dfu/built-in.o
  LD      drivers/hwmon/built-in.o
  CC      drivers/input/input.o
  CC      drivers/input/key_matrix.o
  LD      drivers/input/built-in.o
  LD      drivers/memory/built-in.o
  LD      drivers/misc/built-in.o
  CC      drivers/pcmcia/tqm8xx_pcmcia.o
  LD      drivers/pcmcia/built-in.o
  LD      drivers/pwm/built-in.o
  CC      drivers/rtc/date.o
  LD      drivers/rtc/built-in.o
  LD      drivers/soc/built-in.o
  LD      drivers/sound/built-in.o
  LD      drivers/thermal/built-in.o
  LD      drivers/tpm/built-in.o
  LD      drivers/twserial/built-in.o
  LD      drivers/video/built-in.o
  CC      drivers/watchdog/xilinx_tb_wdt.o
  LD      drivers/watchdog/built-in.o
  LD      drivers/built-in.o
  LD      drivers/dma/built-in.o
  CC      drivers/gpio/xilinx_gpio.o
  LD      drivers/gpio/built-in.o
  LD      drivers/i2c/built-in.o
  LD      drivers/mmc/built-in.o
  CC      drivers/mtd/mtdcore.o
  CC      drivers/mtd/mtd_uboot.o
  CC      drivers/mtd/mtdpart.o
  CC      drivers/mtd/cfi_flash.o
  CC      drivers/mtd/cfi_mtd.o
  LD      drivers/mtd/built-in.o
  LD      drivers/mtd/onenand/built-in.o
  LD      drivers/mtd/spi/built-in.o
  CC      drivers/mtd/ubi/attach.o
  CC      drivers/mtd/ubi/build.o
  CC      drivers/mtd/ubi/vtbl.o
  CC      drivers/mtd/ubi/vmt.o
  CC      drivers/mtd/ubi/upd.o
  CC      drivers/mtd/ubi/kapi.o
  CC      drivers/mtd/ubi/eba.o
  CC      drivers/mtd/ubi/io.o
  CC      drivers/mtd/ubi/wl.o
  CC      drivers/mtd/ubi/crc32.o
  CC      drivers/mtd/ubi/misc.o
  CC      drivers/mtd/ubi/debug.o
  LD      drivers/mtd/ubi/built-in.o
  CC      drivers/net/netconsole.o
  CC      drivers/net/xilinx_emaclite.o
  CC      drivers/net/xilinx_ll_temac.o
In file included from drivers/net/xilinx_ll_temac.h:32:0,
                 from drivers/net/xilinx_ll_temac.c:30:
drivers/net/xilinx_ll_temac_sdma.h:32:3: error: #error LL_TEMAC requires big endianess
In file included from drivers/net/xilinx_ll_temac.c:30:0:
drivers/net/xilinx_ll_temac.h:35:3: error: #error LL_TEMAC requires big endianess
In file included from drivers/net/xilinx_ll_temac.c:31:0:
drivers/net/xilinx_ll_temac_fifo.h:30:3: error: #error LL_TEMAC requires big endianess
scripts/Makefile.build:276: recipe for target 'drivers/net/xilinx_ll_temac.o' failed
make[1]: *** [drivers/net/xilinx_ll_temac.o] Error 1
Makefile:1168: recipe for target 'drivers/net' failed
make: *** [drivers/net] Error 2
Why did I get such errors? How can it be solved? Thanks
I followed the instructions in http://www.wiki.xilinx.com/Build+U-Boot. to compile the u-boot targeting Microblaze.
First, I used SDK to generate 2 important files:
config.mk
xparameters.h
Then, I put these 2 files in the right directory inside u-boot-xlnx folder.
However, I got the following error (something like that) when doing "make"
#error: XILINX_UARTLIT_BAUDRATE undeclared ....
So I went back to xparameters.h to check the content, as expected, there is no value after "#define baudrate_uart16550".
I also tried to manually set a value 9600 inside xparameter.h, but still can not pass "make". After all, I don't know how to manually edit config.mk.
Does anybody know where in SDK the baud rate of uartlite is entered?
from what you have wrote it seem to me that your uboot is expecting a uartlite ip core while you are giving him a full uart ip core.
Thank you very much.
Do you mean this problem might be caused by my operations for hardware part with XPS?
I remember I added RS232_UART_1 to the AXI bus. How can I specify the type of IP to be used?
This is what I saw from Xilinx Platform Studio:
This is what I got from Board Support Package (during SDK)
i didn't see your first printout : it seems that in order to compile ll_temac to uboot you must specify
the __BIG_ENDIAN flag (add -d __BIG_ENDIAN)
