I am trying to play with the connection of two random BT devices and see if they can connect with each other. I found the answer is no. This is what I have:
1. a BT speaker (https://www.amazon.com/AmazonBasics-Portable-Wireless-Bluetooth-Speaker/dp/B01GF5ACUG) that can be used to connect to the smart phone to play music wirelessly
2. a VR headset that can pair with its own BT controllers
When I set device 1 to advertisement mode, and use the smartphone app of the device 2 to look for new BT devices, nothing shows up in the scan list.
Does anyone know what can be the reason to prevent the successful connection between device 1 and 2? Thank you!
Thank you for your advice! I am new to BT and do not know what I can find from the datasheet.
For my initial statement related to "the connection of two random BT devices", I tried to mean one that can be used for transceiver and the other one that can be either transceiver or just receiver. Therefore, for the headset, I assume its BT is a transceiver, and for the speaker, I assume its BT is a receiver. Therefore, I do not know why they cannot be connected with each other.
Regarding your education about "Headset (two ways audio with control) and speaker (only one way audio)", I actually do not know what is the meaning of it. Would you explain it a little bit more or provide some more key words for me to search for the answers?
The speaker can receive bluetooth audio only ... and make it audible.
Thus you need a device that can send out bluetooth audio.
The only possible "audio sent out" of your headset may come from it's microphone.
So is this what you want to achieve? Sending your voice to the speakers while you have your headset on (your ears)?
And then - since the speaker will not send any bluetooth audio to your headset - the speakers in your headset are quiet.
And control signals (if any) won't work, too.
Headset (two ways audio with control) - a headset is a (one or two) speakers for the ears and a mouthpiece.
the goal is to replace a telephone so ones hands are free
the goal is also to let you talk via a computer while on call (such as skype or zoom) without disturbing your neighbors
speaker (only one way audio) - speakers translate electric signals into sound
connecting things is a useful skill
but things go much better if the connection makes sense and has a useful goal
