Nov 3, 2018 #1 L liletian Full Member level 6 Joined Mar 5, 2008 Messages 337 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 3,790 What are the port in the digital design Hi WHat are the port in the digital design? Are they referred to input and output? How about clock? Can anyone please give an explanation or refer some documents? Thanks
Nov 3, 2018 #2 AskSensors Junior Member level 1 Joined Oct 31, 2018 Messages 18 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Location Paris Activity points 112 Re: What are the port in the digital design Hello, Yes, You can consider Input and output as ports. For example, The VHDL considers 5 modes of ports: Input, Output, Bi-directionnal (in/out), Linkage and buffer ports. Here is a similar post in EdaBoard: https://www.edaboard.com/showthread.php?154244-difference-b-w-net-amp-wire-pin-port-terminal
Nov 4, 2018 #3 T timof Advanced Member level 3 Joined Feb 21, 2008 Messages 736 Helped 238 Reputation 476 Reaction score 252 Trophy points 1,343 Location San Jose, CA, USA Activity points 7,778 Re: What are the port in the digital design Usually, a port in a design (digital or analog) is a connection point, interface to the external world. It can be input, output, power supply, etc.
