normally soft macros is coding, it can be implemented in different process easily.
hard macros is implemented in a process, and is optimized for the process. normally it is gds2 file, it is hard to be implemented in another process,
Hi ,
Hard Macro's are usually custom cells / IP which we get from other IP vendors, It is an abstracted view of the IP/Custom cell ,we no need to do design closure with in this hard macro. We just use them like any other standard cell.
hard macro are some module fully implemented and P &R only gdsII and lib will be given by vendor.so that that macro architecture cannot be understand by other customers..
you just import lib and gdsII file in you design..
you just call that component in your netlist and while bounding it will use that component from standard cell library where you imported lib and gdsII file.
hard macros are blocks,for example RAM that are included in a design without knowing actual functionality.So,while performing DFT,these blocks have to be skipped over.
