The unity gain buffer is used to decrease voltage step at the CP output at turn on. Due to charge sharing between the output node and both other sides of the N or P switch, the voltage at the CP output shows a step when both swirchs are turned on, while in idal case the output, which is the control voltage should remain quite... to decrease this effect the buffer is added...
