Hi Guys
I found some people are using tscream and bcream layer, what are the usage of those layers? I seems to never submit a design with those two layers, is there anybody using them before and can explain the usage of them?
Thanks,
Do I need also include other layers? It looks like if I include all layers from 0 to 64, they will report some solder clearance problem.
Here is the link:
Here is the link.
If I do need to include those two layers, how can I fix the problems?
Sorry for the endless questions.
Bests
How are you including the other layers? The layer numbers are 31 & 32 anyway - less than 64. If you add them to a CAM job, make sure that the file you create for the layer only includes the layers you want. For example, don't add layer 31 to layer 29 - they each need their own Gerber file to be generated.
