What are software and hardware requirements for a embedded system mounted on a rifle
jani12
What are software and hardware requirements for a embedded system mounted on a rifle scope?
I need to specify detailed image processing and graphics overlay requirements for state of the art rifle scope? I'm looking to specify the entire pipeline starting from image sensor to display. The specification needs to be comprehensive. It'll be used to select resources such as Integrated circuits, knobs, buttons, memory, etc.. The specification will also drive detailed design document and will be used to validate the final product.
Image sensor needs to be monochrome, with sufficient resolution, high dynamic range. I also need to specify image sensor calibration but what is the need to calibrate image sensor? How calibration works in a typical image sensor from BAE Systems?
The specification should include Reset Initialization specification, Normal Operation Specification, and Fault Operation specification.
It involves taking dark frames for dark frame subtraction to remove static image sensor noise. There is also temperature calibration.
Reactions: jani12
    jani12
The image sensor is infrared.
If you are referring to aerospace application, I assume that it is not a trivial task to be accomplished from a unique approach. They may use more than one camera to provide the necessary depth cognition in order to be able to estimate distances from triangle perspectives, as well as it would be not that implausible to admit the possibility of using some additional resource to make necessary corrections, such as a laser pointer, dynamically focusing lenses, etc...
Reactions: jani12
    jani12
I don't think that makes a difference, you still need to use a "cold frame" i.e. dark frame of no thermal input to determine the image sensors sensitivity differences across the die.
Reactions: jani12
    jani12
