Ways of Feeding in HFSS for fss project
fouad_hagag
I have feeding proplems in fss project using HFSS
What kind of problems are you having. Please elaborate...
I need an example to show me which excitation i should use (incwave or floque port),also the positon of pml boundries, plz
That's not a problem. Which structure are you planning to simulate. Do you have any reference paper/design, so that I can see the design.
Maybe try pressing the pause/break button next to scroll lock
dear fouad
i agree with SV1437
if you need advice, you should tell your problem clearly.
in your case seems so vague..
did your project refers to some paper?
just upload it, and we'll try to help you :)
Best Regards
evyta
this fss structure attached with post iwant to simulate using HFSS .so plz help
  • Frequency Selective Surface Absorber Using Resistive Cross-Dipoles.pdf
thank you for you help,i attached the paper.
For feeding, I defined the ports as waveports and got exactly the same results as given in the paper. How did you try to simulate the ports??
-sv
