samEEEf
Full Member level 2
To make inverter/converter with H-bridge configuration, we have to face difficulties with Hi-low side MOSFET/IGBT driver. IR2110 is commonly used driver for this which has issue with heating up and being damaged found in this forum.
Does anyone have any good alternative chip/IC to the H-Bridge issue?
One thing didn't went through in detail on the commonly used-bridge motor driver IC L298N, L293 etc. Can we use these (or similar high power IC) in inverter/converter?
