Prosenjit101
Newbie level 5
- Joined
- Apr 18, 2013
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Dhaka, Bangladesh
- Activity points
- 1,349
I want to design a Water Level Detector for the water Tank i have in the roof of my building.
I plan on using an ultrasound device.
I will use a PIC16f877A microcontroller.
And connect it with three 7bit segment display.
I expect that i will recieve some kind of an analog input in the input pin of the micro controller.
Furthurmore, i wish to simulate it using Proteus, and generate the HEX file using MPLAB and assembly language.
However, i am not so proficient at this.
What i could do, i will post in the following lines.
Now it will be very helpful if some can guide me,
to what i should do next.
list p=16f877
include <p16f877.inc>
__CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _LVP_OFF
c1 equ 0x21;
c2 equ 0x22;
c3 equ 0x23;
c4 equ 0x24;
s1 equ 0x25;
s2 equ 0x26;
s3 equ 0x27;
org 0x00;
goto start; skip over interrupt vector
org 0x04;
goto serviceinterrupts;
start
call clearall;
call initports;
call inittimer;
call ini_adc;
bsf INTCON, GIE;
bsf INTCON, T0IE;
loop
call ADC;
call B_BCD;
movf s1,0;
call sevensegment;
movwf PORTB;
movf s2,0;
call sevensegment;
movwf PORTC;
movf s3,0;
call sevensegment;
movwf PORTD;
; call delay;
goto loop;
sevensegment
addwf PCL, 1; Add the value of 'W' with PCL(Program Counter Logic) itself & keep result in PCL...
retlw .63; when the value of 'W' is 0
retlw .6; when the value of 'W' is 1
retlw .91; when the value of 'W' is 2
retlw .79; when the value of 'W' is 3
retlw .102; when the value of 'W' is 4
retlw .109; when the value of 'W' is 5
retlw .125; when the value of 'W' is 6
retlw .7; when the value of 'W' is 7
retlw .127; when the value of 'W' is 8
retlw .111; when the value of 'W' is 9
retfie
ADC
bsf ADCON0, 0; ADON: A/D On bit. 1 = 0n, 0 = OFF
bsf ADCON0, 2; GO/DONE: A/D Conversion Status bit. 1 = conversion in progress, 0 = conversion not in progress
; CHS2:CHS0: Analog Channel Select bits [111 = Channel 7 (AN7)]
bsf ADCON0, 3; CHS0 = 1
bsf ADCON0, 4; CHS1 = 1
; bsf ADCON0, 5; CHS2 = 1
polling
btfsc ADCON0,2; Checking for A/D Conversion Status bit. If ADCON0 = 1, loop continues. If ADCON0 = 0, skips "goto polling"
goto polling;
movf ADRESH,0;
movwf c3;
return;
B_BCD
clrf s1;
clrf s2;
clrf s3;
loop1
movlw .100;
subwf c3,0;
btfss STATUS,C;
goto loop2;
incf s3,1;
movwf c3;
goto loop1;
loop2
movlw .10;
subwf c3,0;
btfss STATUS,C;
goto last;
incf s2,1;
movwf c3;
goto loop2;
last
movf c3,0;
movwf s1;
return;
clearall
clrf ADCON0;
clrf STATUS;
clrf c1;
clrf c2;
clrf c3;
return;
initports
bsf STATUS, RP0;
movlw b'00000000';
movwf TRISB ;
movwf TRISC;
movwf TRISD;
bcf STATUS, RP0;
return;
inittimer
clrf TMR0;
bsf STATUS, RP0;
movlw b'00000011';
movwf OPTION_REG;
bcf STATUS, RP0;
return;
ini_adc;
bsf STATUS,RP0;
movlw 0x00;
movwf ADCON1;
bcf STATUS,RP0;
return;
serviceinterrupts
bcf INTCON, T0IF;
movlw .5;
movwf TMR0;
incf c1,1;
retfie; return from subroutine
delay
clrf c1 ;for delay
repeat
movf c1,0;
xorlw .25;
btfss STATUS,Z;
goto repeat
return;
end
