Water down the plug hole
Hot Wire
Does the water flow clowkwise or anti clockwise down your plug hole?
And what country are you in?
You want to know if there is a difference in rotation between the north and south of the equator?
See this link.
https://uk.answers.yahoo.com/question/index?qid=20070319131744AAlb8AR
However I did an experiment when I was on a trip to Kenia ( Country split by the equator). I used a bottle with a very small hole in it, and filled it with water and a little piece of water. The I opened the hole and the water run out. The wooden piece start rotating in the water. I repeated this several times and the direction was the same. Then I did the test at the other side of the equator, a few 100 km away, with the same material and the rotation was opposite! Coincidence?
