warnings in synopsys_DESIGN VISION
manchal
Newbie level 6
Newbie level 6
Warnings:'s[0]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:70: 'c[0]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:71: 'cc[0]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:91: 'cm[0]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:96: 'c[1]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:97: 's[1]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:98: 'cc[1]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:91: 'cm[1]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:95: 'sm[1]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:96: 'c[2]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:97: 's[2]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:98: 'cc[2]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:91: 'cm[2]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:95: 'sm[2]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:96: 'c[3]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:97: 's[3]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:98: 'cc[3]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:91: 'cm[3]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:95: 'sm[3]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:96: 'c[4]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:97: 's[4]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:98: 'cc[4]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:91: 'cm[4]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:95: 'sm[4]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:96: 'c[5]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:97: 's[5]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:98: 'cc[5]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:91: 'cm[5]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:95: 'sm[5]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:96: 'c[6]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:97: 's[6]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
Warning: /home/manchal/manch/finalrow/twodbypass_n.v:98: 'cc[6]' is being read, but does not appear in the sensitivity list of the block. (ELAB-292)
HOW DO I REMOVE THESE WARNINGS.I HAVE DESIGNED A GENERALIZED CODE FOR 4X4,8X8,16X16.ARRAY SIZE VARY FOR EACH CODE.
signals are declared as:
reg [n:0] sm [n-1:0];
reg [n-1:0] s [n-1:0];
reg [n-1:0] c [n-1:0];
reg [n-1:0] cc[n-1:0];//N GIVING ALL SIGNALS (like sm[0],sm[1],cm[0],cm[1]..) IN SENSITIVITY LIST GIVES ERROR.GIVING ONLY ONE SIGNAL LIKE sm[0] solves the error but gives warnings.
My code has warnings in synopsys design vision.Does due to these warnings my report for area and power are affected.pLS HELP.
write always block like this.
always @ *
begin
end
