Warning: NUMERIC_STD.TO_INTEGER: metavalue detected
FPGAs
Member level 1
Shanghai, China
metavalue in std_logic_vector
Warning: NUMERIC_STD.TO_INTEGER: metavalue detected, returning 0
My modelsim report it, why?
How can i solve it?
plese help me with some idea, thanks a lot!
modelsim vhdl warnings numeric_std metavalue
If ur passing std_logic_vector as a parameter to to_integer function and if
ur std_log_vector contains X or Z it will generate the warning you are getting.
To solve this one way is to never allow std_log_vector to contain any other
value than 0 or 1. Or use std_bit_vector!
explain to_integer function
Thanks to nand_gates.
I read a memo in Modelsim help, which is
"These messages can be turned off by setting the NumericStdNoWarnings variable to 1 from the command line or in the modelsim.ini file."
I turn off it in modelsim.ini file, but it don't affect, why?
