ada86831
Hi, All,
When I use encounter to do sroute, I got the following warning. There is no block in my design. Thus I can ignore the warning about block pins. How about the pad ring? How can I solve the problem?
Thanks
**WARN: (SOCSR-1254): Net VDD does not have block pins to be routed. Please check net list.
**WARN: (SOCSR-1255): Net VDD does not have pad pins to create pad ring. Please check net list or port class. (must NOT be CORE class and mus
t not be AREAIO subclass).
**WARN: (SOCSR-1254): Net VSS does not have block pins to be routed. Please check net list.
**WARN: (SOCSR-1255): Net VSS does not have pad pins to create pad ring. Please check net list or port class. (must NOT be CORE class and mus
Thanks
