1000w heater
I can see how quickly the heating wire goes red hot, once powered on.I have got a heating rod of 1000W, but I'm not using it, I have taken all its heating wire and using it in another thing. I measured the resistance of the total wire in the rod and it comes around
46Ohm and I'm powering it from voltage RMS 220V.So W=V^2.R=
1052Ohm quite close to 1000W and
4.78A of current would flow.Anywayz, I am using this wire to wound it on a piece of metal so that it gets hot. The metal plate is this as shown in the figure, attach with wire taken from the heater rod in first picture.
I want to put this metal piece into this RED cloth like this
I don't want to heat the wire very much or else this burn up red cloth envelope,
this is why I want to lower the heat of 1000W heating rod wire
Small Introduction to why I'm doing and where I'm doing.Actually there are two of them and will be attached to this machine as shown below
If you see in the below picture, these two red plates are actually the
two plates of a capacitor. Radiation passes through it and it heats the body, in this case CAT tissue will get heat up inside the cat, it's much like food getting warm up inside the Microwave oven, but the heat generated is very low.
The machine is called as Short Wave Diathermy machine and the problem is that
, the machine doesn't work at all.
I design little part of this machine and it works perfectly![including LCD,microcontroller,buttons, relay timer,stepper motor,etc], the other part of the machine is oscillator making around 10-12Mhz frequency and causing the radiation to be passed from one capacitor plate to another and the body in between will be warm up.It creates relaxation to people when they are tired or have pain, so they use it.
If you look inside the machine, it's totally a piece of junk
Few ideas came to my mind for Heating RED pads with reduced heat and not by radiation, actually this machine is to be demonstrated for 2-5 mintues, once done, story ends here, but the machine is dead, so I'm doing this so that it looks like the machine is really working, but the fact is that it doesn't work at all
(1)I Attached a resistor like 1.8KOhm[I choose this value,because I had this at home] of 5W in series with the heating wire, in this case the current flow should decrease and the wire shouldn't get very hot and shouldn't damage the red cloth envelope, it should give little bit heat and if a person touches on the red envelope pad, he should find it warm and the story ends here.
Result obtain:
This idea didn't work at all. Resistance got burnt up badly
(2)The second idea came to my mind, how about if I use a light dimmer or fan dimmer for this. I have dimmer for this ordinary ceiling fan, I know it's not of 1000W.I have stairs by which I can actually climb and see what's the rating of this fan, but it's in top roof right now.If I take it out from the roof and bring back to the room, it will create noise and it's 2:57AM in night and everybody is sleeping. I will see tommorow morning.Infact I attach all these fans in home :wink:
Question#1 from Point2:
If I use ceiling fan dimmer[I have opened one in the past, and the circuit was almost identical to this one]
If I change duty cyle to low, AC cycle would get chopped and less amount of energy will be given to the heating element , but if I changed the triac to fully on, then full AC would flow and the heating element would get red hot and there would be a chance that this dimmer circuit would get damage, because probably the triac couldn't handle large amount of current.
Is this thinking of mine correct? In other words if this simple regulator is connected with 1000W load or say 1500W or 2000W resistive load, this simple circuit will not get destroyed, if only AC cycle is choped largly and duty cycle is kept low and TRIAC remains off most of the time and gets on for less amount of time.This would then work. but if anybody turn the TRIAC ON all the time and let the TRIAC passes whole of the AC cycle, then this will get destroy(provided the condition that TRIAC can't handle the amount of current)
Question#2:
This is how I have attach the heating wire of second picture, this is a copper sheet and it's conductive and the heating wires are conductive too. What I was thinking that the current would flow in the manner as shown in the figure shown below in left, but what I came to know in the end that it was a copper sheet and the current would flow in the manner as shown below in right. What all the efforts I had done to attach the wire in this manner is gone useless, because it would only happen if the sheet was insulator and not conductor, now the attachment of heating wire is gone useless.The current wouldn't flow through all the wire, but rather it would flow throught the pure copper sheet, because current sees for the path where there's less resistance.
Is this thinking of mine correct? I realized it when I made it.I hope if this thing come to my mind before.
I know I'm using AC source, so direction doesn't matter.Current flow to and fro, but I made them to tell you people the flow of current.
Please tell me whether my thinking is correct or not?
If there's any other good way to do please tell me, any comments, suggestions are highly appreciated
