Wanted : PCB antenna vendors (line .1mm; via .2mm; min space .005mm; on Roger 5880)
y99lx
Member level 1
Hello, friends,
Can anyone provide a PCB antenna vendor/manufacturer with the capability:
Look forward to hearing from you.
Tom
In china, if the line width is 0.15mm, the yield rate is very low. So it's very expensive.
The minimum via should be 0.3mm, and the min space is 0.15mm.
