I assume you spent a lot of time searching through the internet....searching through this forum....checking the 'similar threads' in the box below.
For sure you found a lot of code.
To help you we need to know what "exactely" is wrong with these codes.
What else do you need?
Klaus
You can indeed use the FFT in some mid range microcontrollers, however with a very restricted scope of applications and it certainly will not meet your expectations, as for instance not doing it in real time, as well having a poor resolution. Many time ago I made some experiments to take the frequency spectrum of a recorded 60Hz mains sinewave with a 16-bit core microcontroller ( namely the Texas MSP340F1xxx ), which even having 2K words of RAM available, the best resolution achieved with the simplest code it was just 127 points. In shorts, as said above you need provide more details.
