waeco sinepower. sp1000 inverter cut off at less than 5min when switched on
Abdulhakim
Newbie level 5
Newbie level 5
waeco sinepower. sp1000 inverter cut off at less than 5min when switched on pls what is the solution
could be several reasons
short in the load
overload
bad battery
bad internal part
over-discharged battery
solution depends on the problem
the device connected to the inverter has a short-circuit or is overloading it
