The acceptable level depends on your application. In "my" applications -15 dB is "good". If you are dealing with precision horns for satellite antennas "good" is -25 dB.
Also, you can look at www.microwaves101.com
In the "search" box write VSWR.
It will clear every element of doubt and it has a very good tutorial. good luck!
