vsim 7 Failed to open VHDL file "us2test/mspfiles" in r mode
abu9022
Member level 3
Member level 3
Hi friends,
I am trying to run the following command
vsim -sdfmin /tb_msp/p0=output.sdf -t ps tb_msp
I have the following error, can you help me how to solve the error
# ** Error: (vsim-7) Failed to open VHDL file "us2test/mspfiles" in r mode.
# Not a directory. (errno = ENOTDIR)
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/mspram0
I means it cannot open the file/folder us2test/mspfiles. Make sure this folder exists
The tool is trying to read the file "mspfiles" from the path you specified in the environment. So either ensure that the file is present in the given path or find out the correct path and and specify it...
is there any command in linux to find the file in directory?
