dinesh401
the servo motor is given running current and stall current, after studying about those currents i understood that, while the motor is rotating its shaft to reach its desired position it will take more current i.e., the stall current,
whenever it reaches to its desired position and it is stable in the position, at that time it takes some current, i.e., the running current.
is it correct what i said ?
datasheet of servo motor
https://www.strikemodels.com/wp-content/uploads/VS-2-Servo.pdf
