voltage source impedance
G
Hi
Where can I found information about how to construct a low impedance source!? I need a power supply that can deliver DC current pulses (1ms) with a very low rising time.
Thanks in advance
Best Regards
Pendragon
This pulsed current is usually sourced from a capacitor that is large enough to supply the charge without declining in voltage too much. To reduce the parasitic resistance and inductance you usually have several smaller value, but higher quality, capacitors in parallel at the output of your power supply.
Hi
Ok, thanks.
Iis capacitor the only solution!? or the best one!?
There are others solutions!?
I think that another solution will be to feed the load with a battery. But this is not very confortable.
thans again
Best Regards
Pendragon
The battery is certainly one option. The problem will be the life of the product. After a few years the battery will degrade and the circuit will not work properly. There is also the problem with the internal inductance of the battery. They are not designed for pulsed loads.
Yes what you say is true and makes sense.
An alternative to a voltage source will be a controled current source. source Inductance will influence maximum current rise rate, but this don't give bether results!?
Numbers please! How much current? How much voltage compliance? How low impedance? How low risetime?
