I'm powering an MCU through either 4 alkaline/Ni-MH or 2 Li-Ion cells. The maximum voltage the MCU can handle is 6V and the BOD level is set for 3V. When 2 Li-ion cells are used the input voltage will be ~7.4 volts and I'd like to regulate this voltage to prevent damage to the MCU. When the device is powered with alkaline cells no voltage regulation will be needed, but it will be needed with the Li-Ion cells.
I'd like to just use a LDO with a fixed output at 5.5V, however, all LDOs I've seen feature under voltage lockout. Therefore, they won't power my device unless the voltage is above 5.5V + the dropout voltage.
Is there any way I can have a voltage regulator that is free conducting below a certain voltage, and above it regulates the voltage?
