rhnrgn
Member level 5
Hello,
I need to obtain some voltage levels below 5Volts from 5Volts power rail. I am thinking about to use PWM with 10Khz modulation frequency. For example with %50 duty cycle i am planing to get 2.5Volts.
In order to this i am planing to use the circuit below.
My load has resistive character. Thermoelectric Cooler (TEC).
According to our design TEC will draw 0.8 amps avarage at 2.5 volts.
Questions:
1_According to your experiences will there be any problem that i should be aware of?
2_In order to get linear voltage at the output of PWM driven voltage i added C16 and C17 as low pass filter. Are they necessery, if so are they ok as 10nf and 100nf or should i use 1uf or higher?
Best Regards:thumbsup:
Questions:
